Philj6970
Flight distance : 840663 ft
1) Take off the broken propellers and check the motor tops to see if anything is broken off there, should be 3 posts on each.
2) Check free movement on each motor's rotation
3) Check that the motors are all straight
4) Calibrate IMU's
5) Calibrate Compass
6) Calibrate Gimbal
7) Calibrate vision cameras (need DJI Assistant app and PC)
8) Check fit of battery in battery compartment
If anything is wrong with the flight systems the drone will tell you during calibration.
Keep your first flight after a crash short and close, until you are sure its flying ok. |
