terrylewis
Flight distance : 3517287 ft
DJI Lightbridge uses radio channels which are within the ISM bands to transmit between the RC and the aircraft. The Phantom antennas communicate with the RC on 2.400 GHz - 2.483 GHz. DJI initially implemented 32 channels within this band but later discovered that only 8 channels (13 -> 20) were legally available in various regions.
The other frequencies are in used by ham radio, satellite communication, or are used by wireless carriers in various countries. Those channels outside DJI 13 to 20 may not be legally usable for "public" communication. See this spreadsheet for specific channel usage:
https://docs.google.com/spreadsheets/d/1WuKQD3FvbtFnJ6wkFu9DLxhdxHCSsnZPi90CwTGj3ks/htmlview?pli=1#gid=1477125990
Sploodge outlined a GO App hack to enable custom selection of the original 32 channels here: http://forum.dji.com/forum.php?mod=viewthread&tid=27147&fromuid=44480. Please use at your own discretion!
Also understand that the GO App automatic channel selection ONLY works within the 13 -> 20 channel range. In order to even use the channel hack, you must select CUSTOM channel and manually select the least interference channel. Thus in countries where CUSTOM channel select is prohibited, you must additionally bypass this prohibition to use the hack.
Thus, understand what you are doing and use at your own discretion.......
