gtokarsk
Flight distance : 14869882 ft
This is a P3, not 4, but aside from that, yes, I did look at the wind, but unless I am in atti mode, the GPS should have held the position against the wind. If there was an indication that I went into ATTI non gps mode, I would totally buy what you just said - it would make perfect sense.
Here's a scenario where i flew with serious gusty wind, and did not have such issues, hence my suspicion of something deeper perhaps...
http://healthydrones.com/main?share=RImVBZ
But, just because I have not noticed it before, does not mean it did not happen, so I will agree with you that this is a very good working theory.
Now, if this caused a crash though, I would still consider it a failure of DJI's flight envelope....
So if that is the case, that even such minor wind can have such a stron effect, DJI needs to confirm it, define it, and put this in the manual as a warning of some sort, that if there's wind, and you do a low stick input, the gps lock may not work well.. 10mph wind, in my mind is not enough to cause this issue - but that may be just my expectation. I will do way more testing of this scenario at low altitude, open area, with similar wind, perhaps in "landing" mode....
Thx for the idea!
Oh, I just reread you post, and yes, the low battery and power required to hold position, is another piece that could make sense... So I changed my settings to 20% 10%, I may need to flip them back to 25% 15% perhaps....
Again, if DJI can confirm with pretty good confidence, I'd buy that.. Power management IS also an important part of flying....
GT
