Aardvark
Flight distance : 384432 ft
OK, using DJI Assistant downloaded to a PC. Install application and usb driver (it's all there), if not already done. Connect drone to PC with USB cable and power up. Run DJI Assistant, select P4 device , when it opens up there is an option down the left hand menu that allows you to calibrate the cameras (sensors). Takes a couple of minutes to do and a steady hand |
