CrimsonPhantom
Flight distance : 179974 ft
Donsio and Jaime,
I've done a little more experimentation and have come to the conclusion it's my monitors. I don't quite know the issue with them but would be very interested in hearing your opinions.
My dual monitor configuration consists of two DELL 2007FP monitors. From the dell site, here are the specs:
Display Type : LCD Monitor
Diagonal Size ( Viewable Size ) : 51cm (20.1") (51cm (20.1"))
Panel Type : VA - Vertical Alignment & IPS - In Plane Switching
Maximum Resolution : 1600 x 1200 Pixels at 60 Hz
Response time / Brightness / Contrast Ratio : 16ms / 300cd/m2 / 800:1
Dimensions w x h x d : 547.6 x 367 (extended / compressed) x 445.3 x 193.5 mm
Weight (panel only - for VESA mount) : 5.2 kg (11.5 lbs)
Weight (with packaging) : 9.6 kg (21.2 lbs)
Features : VESA® 100mm Mounting, Anti-glare with hard-coating 3H, Slim Black or Silver Bezel, Includes Height Adjustable Stand
Connectors / Ports / Slots : USB / 15-pin D-sub / DVI-D / S-Video / Composite Video Connectors
Voltage Required : 100 to 240 VAC, 50 Hz to 60 Hz
I removed my #1 monitor and replaced with a Dell P2210T. Again, here are the specs:
Diagonal Viewable Size:
22 inches (558.68 mm) viewable area
Aspect Ratio
Widescreen (16:10)
Panel Type:
TN - Twisted Nematic
Optimal Resolution:
1680 X 1050 at 60 Hz
Contrast Ratio:
1000 to 1 (typical)
Brightness:
250 CD/m2 (typical)
Response Time:
5ms panel typical
Viewing Angle
(160 vertical / 170 horizontal)
Color Support:
16.7 million colors
Pixel Pitch:
0.282 mm
Device Type
Widescreen Flat Panel Display
Here is the display information as operating on my system:
Monitor 1: DELL P2210T:
1680X1050, 60 Hz
Monitor 2: DELL 2007FP
1680X1200, 60 Hz
Running the calibration with the cal window on Monitor 1 (DELL P2210T), the calibration passes, and on Monitor 2 (DELL 2007FP) the calibration fails.
Monitor 1 Cal
Monitor 1 Cal Screen
Monitor 2 Cal
Monitor 2 Cal Screen
