DJI-Ken
Flight distance : 1515312 ft
It's working fine, when you go into the editor tab, then click photos, then tap the circle of the photo/photos you want, then the circle turns yellow with a check mark in it and you see the down arrow in the bottom left corner, tap that and then tap save to camera roll.
Are you saying that is not happening?
If you have the aircraft on and everything connected, you can download the original full resolution photo and you should see a box in the middle that says "Download original Photo". Do you not see that either. |
