DJI-Paladin
Flight distance : 2408 ft
Currently the Phantom 3 4K's firmware is 1.5.4. It is recommended to keep the firmware up to date and adjust the RC and antenna position during the flight. If you want to downgrade it, you can try these steps:
From the main home page, if you press the graduation hat (upper right corner) and press it for 5-10 seconds then let go, it will take you into the downgrade menu. |
