Loose antennas
vze369t9
Flight distance : 491175 ft
1#
Whenever I install my Skyreat signal extenders, both antennas flop over. I am constantly moving them back into the correct position. Is it possible to tighten the antennas? The signal extenders work great, I just need to tighten the antennas so they stay in position. Or is there another fix I could use to correct my problem?  Does anyone know if this is even possible and if it is, how do you do it. Thank You in advance for the help
2016-6-3
gil
Flight distance : 1379308 ft
The version I got on eBay included a couple of clips that you could slide into the base of the antenna (shown at bottom of photo).  You could fabricate something similar out of some scrap plastic or I suppose you could try and contact the seller I bought from and see if he will sell you just the clips.
http://www.ebay.com/itm/Phantom-3-Inspire-1-Controller-Video-Split-Antenna-Range-Booster-KIT-/252097467637
2016-6-3
vze369t9
Thank you for the help
2016-6-5
homerdom
Ukraine
Hi all, After installing the firmware 1,6,8 bird began to fly up to 50 meters and then lost the video signal. I actually helped with the installation of this version of the firmware 1,5,7: P3S Signal Issue FIX http://forum.dji.com/forum.php?m ... D369%26typeid%3D369 but first I put the version dji-go-2-7-2-apkplz.com.apk, I do not remember where , but just at this forum there is a link . After installing the firmware 1,6,8 bird began to fly up to 50 meters and then lost the video signal , now all works well , 120 meters stable video transmitted. Thank you very much to the author !
2016-6-9
