info
Flight distance : 7014 ft
Hi all
Ive just built up a medium-size quad (modified Tarot 960 frame converted to quad from Hex and cut to 750 size)
Motors are T-Motor 3520 400kv with 18x 6 T-Motor beechwood props, running on 30A Hobbywing Platinum ESCs, running 10,000mah 6S.
AUW is 5.3KG
Currently running gains at 120, 120, 120 / Atti 120 120 120
The problem Im having is its incredibly unstable in a breeze.
In still air ir flies and hovers ok (though still suffers from altitude drops a bit)it also seems to drop when i yaw, but only when i yaw RIGHT and only when it passes 90 degrees!!!?!?!!
In a breeze it will vary by up to 2m!!!!
Im thinking it might be gain related...?
