Geebax
OK, here's some answers for you:
'dJI-ken: no video signal with almost full bars.'
Yes, the full bars represent the signal strength as rreceived at the aircraft, they have no relation to what is coming back in the other direction, which is the video signal. It is the return signal that fails first.
'And I also detected another problem. When trying to activate the folow me mode, my p3s says that satellite signal is too weak with 9 satellites!!!!'
Yes, again you do not understand what is going on. The RC unit is reporting that it is getting a weak GPS signal from your phone/tablet connected to the RC unit, the display on-screen is showing the number of satellites that the aircraft is seeing. This is because phones/tablets have crappy GPS receivers, while the one in the aircraft is a much better receiver. Oh, and by the way, 9 satellites is pretty poor, a good number is 12 or greater.
'I will insist once more, please release a firmware update.'
You can insist all you like, it will make no difference, if there is an issue, DGI will release a firmware update when they are good and ready, they don't adhere to your timetable.
