soundbyte58
Flight distance : 300761 ft
I agree with you, it looks like interpolation errors to me too. I think they are caused by lens parallax errors and this is why only the high roofs are distorted. I think the drone was flying to low and the software is having problems with the roof because overlapping frames are seeing different angles. One frame is seeing seats under the roof and the frame beside it does not, so the software is shifting the roof around in order to make sense of the only regular pattern, which is the seating. The lenses field of view is too wide. I would suggest redoing it at a higher altitude, so that the roof is at a lesser distance to the ground, relative to the lens. Also shoot many more frames with at least 50% overlap or better. Take your originals and crop away the outer 50% of the frame. This will leave images with less parallax distortion. It gets worse toward the edge of a wide angle image. Phantoms use consumer grade cameras with a fixed length lens (no optical zoom). Google maps achieves the sharpness by zooming in at a much higher altitude so the images practically stitch themselves together. But if you look closely at the upper left quadrant of the google image, you can see the same type of distortion between the seats and the roof. The other quadrants look good because the stitching algorithm is giving priority to the roof edge, rather than the seat pattern under it. |
