Flipperman
Flight distance : 4224925 ft
Has anyone else noticed a distinctive reduction in climb rate following the upgrade to 1.09.0060 ?
One of the things that amaze new people to seeing the drone is it hovering and then suddenly climbing. I've definitely noticed a reduction in the performance.
DJI - you noted cold weather adjustments for batteries. I assume climbing is one of the biggest draws on the battery over and above forward flight and hovering - have you reduced the speed at which the drone now climbs following this update ?
