My Phantom 3 Professional started emitting a loud beeping noise upon startup last night. I installed the latest firmware on it 1-2 weeks ago and it has flown fine up until this point. I checked the SD card and everything seems to be ok there. I checked the log file and under yesterdays date "7-02" It only shows the firmware file code but nothing else. I tried my other SD card with the previous firmware on that to see if it would change anything and I did not. I did a google search and some on here mentioned letting it sit for awhile and let it do its thing. That did not solve it either. I am getting a green light above the gimbal but a red light above the bottom sensors. Battery indicators are normal. I can connect with my DJI Go App and the controler and it comes up saying everything is normal but then it says battery level 0%. Tried both batteries fully charged and the same thing occurs. Gimbal appears to be ok mechnically. If you move it while carrying it the gimbal will flinch like when moving side to side. Any suggestions would be greatly apperciated! Trying to get it up for this afternoon.
Thanks!
Sounds like a dumb question to ask. But how do I do this? I have both the controller and the aircraft on while it is doing this. Controller shows a green light on the bottom.
look in that app for where it says re-link controller (remote controller settings page),then press the button beside the red light on the side of the vision positioning modual (under battery bay)
Jetboys Posted at 2016-7-3 11:24
look in that app for where it says re-link controller (remote controller settings page),then press ...
Thanks for the help! Even though it is beeping loud the text file now shows "Upgrading" for today's date. I guess ill let it do it's thing now for a bit. Thanks again!
Be sure you remove the update file from your SD card so it doesn't keep trying to update every time you fire it up. The log file is fine and good to keep. Just thought I'd throw that out there.
Thanks for the heads up! Loud beeping has stopped now and it has gone back to the regular updating beeping sound. Sign of relief for me as earlier I thought I had a major issue going on.
