Calibrate Controler to Pan Camera
1943 17 2015-1-23
kevin.hanscom93
I am new to the drone world.  I received my new Phantom 2 Vison+ a couple weeks ago and I have been getting used to it before sending it in the air.
My question relates to controlling the camera pan with the roller control on the controller.  It operates the gimble to pan up and down; however, it does not stay in any position below horizontal as it slowly pans to the horizontal position when the roller is in the neutral position.  I tried calibrating several times but it doesn't fix the problem.
Also, I am unable to control the camera pan using my iPhone.
Any suggestions?  Thank you in advance.  I hope to do a test flight this weekend.
Kevin
2015-1-23
Gerry1124
This works for me after I initially calibrated in the RC setup.
2015-1-23
kevin.hanscom93
Gerry1124 - Thanks for the response.  I tried this calibration and it didn't fix my problem.  Pan camera all the way down and it slowly moves back to horizontal position after about 15 seconds while the control knob is in neutral position.
2015-1-23
Gerry1124
kevin.hanscom93 Posted at 2015-1-24 09:25
Gerry1124 - Thanks for the response.  I tried this calibration and it didn't fix my problem.  Pan ca ...
Did you follow these instructions?  Did you calibrate the X! when you were connected to the RC program on your computer first? Your transmitter is not connected to the computer when you do this calibration..
2015-1-23
kevin.hanscom93
It was not connected to my computer.  I went through the calibration according to the instructions and received the audible responses indicating that the calibration was successful.
2015-1-23
Gerry1124
kevin.hanscom93 Posted at 2015-1-24 09:34
It was not connected to my computer.  I went through the calibration according to the instructions a ...
Did you also move the camera wheel?
2015-1-23
kevin.hanscom93
I followed the instructions by moving both sticks to their travel limits and the camera wheel to maximum positions and returned to neutral.
2015-1-23
Gerry1124
kevin.hanscom93 Posted at 2015-1-24 10:03
I followed the instructions by moving both sticks to their travel limits and the camera wheel to max ...
Did the camera move to the extreme horizontal and vertical limits?
2015-1-23
kevin.hanscom93
Yes, extreme vertical limit (only moves pointing horizontal to straight down...no horizontal pan) and then it slowly returns to horizontal
2015-1-23
Gerry1124
kevin.hanscom93 Posted at 2015-1-24 10:11
Yes, extreme vertical limit (only moves pointing horizontal to straight down...no horizontal pan) an ...
When you calibrated it in the PT2 program, did you do both the "command stick calibration" and the "X1 calibration"?   Also did you have the upgrade version selected?
2015-1-23
Gerry1124
PT2 calibration page
2015-1-23
kevin.hanscom93
I am running 3.6 version software so my screen doesn't match yours (I don't have the upgrade version/basic version option).  Yes I calibrated X1
2015-1-23
Gerry1124
kevin.hanscom93 Posted at 2015-1-24 10:29
I am running 3.6 version software so my screen doesn't match yours (I don't have the upgrade version ...
You have the camera control wheel in the top left corner of your transmitter?
2015-1-23
kevin.hanscom93
that is correct
2015-1-23
Gerry1124
I have the vision + and the transmitter with the control wheel also.  I have version 3.6 PT2.  Below is an actual screen shot of pt2 with the Phantom connected.
2015-1-23
Gerry1124
3.6 version of PT2
2015-1-23
kevin.hanscom93
I didn't have the RC tab selected.  I calibrated from that screen and it seems to be working now.  Thanks for working though this with me.  I really appreciate it.
2015-1-23
Gerry1124
kevin.hanscom93 Posted at 2015-1-24 10:46
I didn't have the RC tab selected.  I calibrated from that screen and it seems to be working now.  T ...
Great,  glad to hear it.  Happy Flying!
2015-1-23
