zenmuse x5 crahs
1487 16 2016-7-12
piymamen
Flight distance : 456260 ft
Hi.
today I had a problem with my x5 zenmuse and my matrice 600.
after spending four sets of batteries I've put the fifth game and went out to fly mid-flight camera released me no more.
the matrice 600 has no more than 15 hours of flying and I rode all the official servivio.
if this is not a fault been a defective media or if something was wrong mounted from the official service.
DJI know some case like this?
It could drop support because of the vibrations?
I hope you take responsibility in the Sevice.
I wait for your answer.
2016-7-12
DJI-Jamie
Flight distance : 112405 ft
I'm sorry, I do not fully understand the issue. Are you saying that the X5 fell off of the aircraft while flying?
2016-7-12
piymamen
It apologize for my English is google translator.
if my zenmuse x5 detached from the aircraft
after making 4 flights of 30 minutes or longer.
in 5 flight broke off for no reason.
an had this problem with other users?
It can be devido vibrations?
thanks for answering so fast.
I hope takes charge on official service
2016-7-12
DJI-Jamie
piymamen@gmail. Posted at 2016-7-13 04:53
It may be due to vibration, but I would need more information. At which connection point did the gimbal fall off? Was it from the gimbal lock connection or did a part of the X Mounting base come off? Do you have a picture showing what parts fell off?
2016-7-12
piymamen
photo sent it tomorrow have in the office.
the support was complete on the aircraft.
It fell off the safety lock.
an ever had this problem ??
2016-7-12
DJI-Jamie
piymamen@gmail. Posted at 2016-7-13 05:25
It would help to see a picture. Just to confirm, were you able to lock the gimbal into place? The lock indicator line did line up in the center prior to taking off? Was it hard to lock or was it easy?
2016-7-12
piymamen
[img]if the line of the blockade was in place before takeoff.
mounting the closure was easy.
Tell me mail address and if you want you sending flight data.
in the recording it looks like the image has many vibrations.
I have the data generated by the app DJI when these also have the video recording generated by the app .  if you want to send him the data for research
2016-7-13
DJI-Jamie
piymamen@gmail. Posted at 2016-7-13 16:48
Unfortunately the image did not post, could you resend it? It would be best to use the picture option via the Advanced tab of the reply section.
2016-7-13
piymamen
2016-7-13
piymamen
https://drive.google.com/folderv ... UHc&usp=sharing
2016-7-13
DJI-Jamie
piymamen@gmail. Posted at 2016-7-14 01:02
https://drive.google.com/folderview?id=0B2M1oYm8ApshY0o3eVR1aFNrUHc&usp=sharing
Thank you for providing, it may take me a bit to go through it with some technicians. Regarding flight data, could you sync your flight records from the DJI Go app via the Flight Records section of the app? You will see a cloud icon on the top right.
2016-7-13
piymamen
THANK YOU JAMIE.
I JUST FLIGHT DATA SYNC FROM THE APP.
I HOPE YOU FIND DJI reason for this failure.
I lost 2500 EUROS AND NEED THE CAMERA to work.
If you need any more information let me know SOON AS POSSIBLE.
A GREETING
2016-7-13
DJI-Jamie
piymamen@gmail. Posted at 2016-7-14 15:57
THANK YOU JAMIE.
Could you tell me what your DJI Account email is and what day this issue happened? Just to clarify, you did not detach an reattach the gimbal at any point between your multiple flights?
2016-7-14
piymamen
Hello.
my email is piymamen@gmail.com
the failure occurred on 12/07/2016.
  I have six consecutive flights that day. 9 last minute flight into the chamber of the aircraft is released.
I bought another camera and I'll just start an investigation myself.
I will make several consecutive flights with a gopro recording directly to a safety lock.
I hope that together we discover the fault.
the seller of Spain treated me very badly.
thank you very much to DJI for their professionalism.
2016-7-14
DJI-Jamie
Thank you, I will let you know what I can find out for you. In the meantime, I would highly recommend starting a Repair Service with our Europe Support team, so that your X5 will be up and running again. Have you already started a RMA with them by any chance?
2016-7-15
piymamen
HI.
I HAVE NOT MADE ANY REPAIR BECAUSE THIS completely destroyed.
If they start an investigation and tell me RESULTS.
THE TECHNICAL SERVICE IN SPAIN TO HAVE YOU are incompetent.
SEARCH SHOULD GIVE YOU THE DISTRIBUTION TO ANOTHER COMPANY.
THANKS GREETINGS.
2016-7-18
DJI-Jamie
piymamen@gmail. Posted at 2016-7-18 18:26
HI.
Of the 6 flights that are present for that day, all of them appear to be complete flight with no errors. I do not see another flight where the camera had come off. Instead of dealing with your seller, I recommend contacting our DJI Europe office directly for a warranty claim. Based on the information provided thus far, I cannot tell for certain whether the issue occured from the X Mount itself or the camera. If the unit was secured properly, the camera would not come off even after multiple flights.
The best course of action would be to email support.eu@dji.com to look into having the X Mount and X5 evaluated by a DJI repair technician to see if there is a quality issue with either components for a warranty claim.
2016-7-20
