wcough
Flight distance : 10566736 ft
To use the radiometric picture with the embedded data, as the other users have said , you have to select the picture type as the radiometric jpeg.
And at the end of the flight when the photos syncs with your tablet, those photos will not include the data,,, you must view them and select which ones to download within the app to view the embedded data,
or just remove and copy from the sd card itself. the data added to each jpg increases the picture size by about 750 byted per photo From there you can import them within the flir tools program. use the edit button within flir tools to pull the needed data and assign which data you wish to show your client. There s a learning curve to it but after you do it once you'll be smooth sailing
Hope that helps you |
