johnwarr
Flight distance : 6467 ft
First thing to check are the 4 rubber dampers on the gimbal, make sure they are not torn and that the 2 anti drop pins are fitted properly. They need to be able to move freely, not cable-tied tight to the mounting as I have seen some fitted.
Next would be the props as out of balance or damaged props will cause a lot of vibration. |
