Mike.sonne
Hey all!
So I finally pulled the trigger and purchased a P3 Pro on sale. I recieved the UAS on Wednesday and spent most of the night charging and updating. I spent some time flying on Thursday morning, I had very 3 successful flights. The 4th flight was rough. Less than 5 minutes in the drone flipped over. I immediately throttled down on the remote and saw the P3 throttle up and smash into the concrete. I ran to get the P3 and saw that I lost connection on the remote (Galaxy tab S with 4G) When I turned it over the props went full throttle and I had zero input control. I was holding onto this unit and keeping it away from my face and body parts. It "seemed" as If I would have let go it would have just flown away at full speed. I switched to ATTI mode and after about 5 minutes of holding onto the P3 with dear life, I finally regained control and I was able to power her down. Talk about nerve wracking!!!
So I immediately noticed I broke a prop and took a nice little chunk out of the top half of the body shell. There is also some slight warpage where the top of the body meets the bottom. Less than a quarter inch. Luckily it looks like just the top shell needs to be replaced. I let the p3 cool down, the motors could have cooked a steak they were so hot. After 30 minutes I replaced the props and battery. I recalibrated and went for a test flight, thankfully she could still fly! No erroneous behavior and stable hovers. She drifted about 3-5 inches in each direction, but from what I've experienced and the videos I've watched, that seems to be normal in 10-15mph winds?
I'm just curious as to what I could have done differently to regain control. I've scoured the manual, forums and the web. Seems like I did what I should have. This is my 4th drone, I've repaired others, thats not a problem to me.
Now my question is, when this was happening I kept recieving IMU failures on my tablet along with no connection. Once I regained connection, all the errors were gone. I understand clipping the tree was 100% user error, but the lost connection? Is that a failure of the tablet? The drone was less than 40 feet away when all this happened.
I called DJI, sadly they weren't very helpful. Before I could even finish explaining the situation, the rep just started with a bunch of canned statements.
I did calibrate the compass and recalibrated the IMU. Another thing I noticed was the DJI app said the controller needed to be updated, yet I already had the latest version. I did power her up again last night and the update message was gone.
What say all you?
