Aardvark
Flight distance : 384432 ft
Best thing is find a big wide open field with no obstructions where you can practice take off and landing etc. Handy to have a sheet of plywood or similar (about 600mm square, or whatever suites you), then camera/gimbal won't get dirty or damaged. Have a good read of the Return To Home (RTH) section, and practice the different scenarios (try less that 65 feet away and then more) to build up confidence. Don't rely upon the Obstacle Avoidance as being perfect, it can't avoid small obstacles, so have a good read over that section. |
