live view problem on dji go
2905 9 2016-8-25
rahmani
Flight distance : 46791 ft
Iran
i have this error(see pic) when tablet connect to remote control can not get live stream
i have phantom4
and my device is Samsung Tab S2 8" with android 6.0.1 and i install Dji go app version v2.8.4
also i enable MTP and Usb debugging and i using usb cable with choke
and i try with other device and system fully work but in S2 tablet it didnt work
please say what i should to do?
thanks
2016-8-25
rahmani
Iran
also i install smartswith app but it didn't effect
2016-8-25
DJI-Jessie
Hello rahmani, please refer to our device support list. S2 tablet might be not compatible with the DJI GO APP.
IOS Version v2.8.7.
Requires iOS 8.0 or later. Compatible with iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus,iPod touch 6,iPad Pro, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4, and iPad mini 4 Wi-Fi + Cellular. This app is optimized for iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s and iPhone 6s Plus.
Android Version v2.8.4.
Requires Android 4.1.2 or later.Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Huawei Mate 8, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
2016-8-25
mmarkoe
Flight distance : 15135 ft
Since the marshmallow 6.0 update on my Samsung Tab A, I have to set the USB debugging mode to RNDIS, not MTP.Marty
2016-8-26
rahmani
Iran
i thinks the dji go app not compatible with android marshmallow 6
2016-8-26
Enkeixpress
Flight distance : 297497 ft
Use a different cable, or try enabling USB debugging in settings > developer options. Also try changing from 'MTP' to 'USB Mass Storage' mode or vice versa, until it works.
2016-8-26
DJI-Ken
Flight distance : 1515312 ft
rahmani Posted at 2016-8-26 20:59
It is compatible, it's your device that may not be compatible as it's not a DJI recommended device.
You have to search to see if changing configurations may get it to work.
2016-8-26
rahmani
Iran
by this way i get live stream
http://forum.dji.com/forum.php?m ... &fromuid=383106
but tablet must be restart each time i connect usb cable
2016-8-26
davis.berzinjsh
Can you help me.....how to set up RNDIS mode? I have samsung galaxy tab A 9,7"
2016-9-7
djiuser_jJvsnHq
Flight distance : 131220 ft
Norway
Install USB driver for Android, and exstract before u launch DJI GO 4.
2017-9-3
