Hello. I bought lightbridge and connect with my naza m v2 + futaba T14SG. Additionaly I have retracted gears on my tarot frame and non DJI gimbal. To control my gimbal and gears I need to extract 4 channels (9-12) from DBUS. To solve this problem I bough FrSky SBUS decoder http://www.hobbyking.com/hobbyki ... to_PWM_Decoder.html
I programm it and it work fine with futaba reciever (only with S.BUS2), but non with lightbridge.
Please advice working decoder to extract 9-12 channels from DBUS.
Because the Lightbridge system acts as its own receiver, the SBus decoder may not work properly. Could you clarify how the unit behaves when using Lightbridge?
When all channels in FrSky decoder was mapped at 1st SBUS channell (default settings) - it's work fine. But when I remap to 9-12 channels - nothing happens. Maybe lightbridge not encode channels > 8?
Yes! Lightbridge send 1-8 channels through red jack, and other 9-16 channels through black jack in "Y" remote control cable. In standard packet also present single remote control cable, but it send only 8 channels, however in manual specified 16ch. If I switch TRAINER in my Futaba from 8 channels to 12 or 16 channels nothing is working. How I can transmit all 16 channels through 1 cable?
Since the 14SG can only use 14 channels, it may not recognize it set to 16 channels. The Futaba should work when set to the 12. Is the firmware up to date on all the components? Are you only using channels 1-12 and not 13 or 14?
