Cessna172
![](https://forum44.djicdn.com/data/attachment/common/c5/common_13_usergroup_icon.png) lvl.4
I finally found cracks in the shell of my Phantom around the motors. Thus busting the idea that prop guards prevent shell stress cracks {:4_157:}
In any event, I repaired them pretty easily. The secret is a substance I already had onhand for other acrylic / polycarbonate plastic repair.
It's called Weld-On 4
Turns out the plastic on the DJI Phantom is the perfect material that this works on.
With a hyperdermic needle applicator, you can flow a small amount diretly onto a crack and it will wick into the crack nicely, then in about two hours, fuse the crack back together better than the original plastic. It melts the plastic very quickly on the edges of the crack then the two sides of the crack flow together then harden. It's exaclty the same basic principle as steel welding. Once dry, it is unlikely you will ever have that same crack again. It will crack somewhere else first.
Be careful not to fuse the upper and lower shells together. Once done, they are ONE SOLID PIECE. What I did to repair one motor pod was remove all the screws for that pod then slip a piece of paper between the upper and lower shell before I began the welding (glueing) so no glue would wick between the upper and lower shells.
This works very well and is very quick and durable. If you'd rather not send your Phantom back and want to gt back in the air asap....this is it. Good luck.
It's also a MOST EXCELLENT crack stopper. If you see a crack just beginning, just wick a tiny dab of this on the crack. It will wick into the crack and weld it back together stopping it cold in it's tracks.
Here's one link to the item on ebay....there are quite a few sellers selling it so shop around.
[url=http://www.ebay.com/itm/IPS-Weldon-On-4-Solvent-Acrylic-Plexiglass-Glue-4-oz-Applicator-2-needles-/122007661776?hash=item1c68392cd0:g NYAAOSwcldUZWru]http://www.ebay.com/itm/IPS-Weldon-On-4-Solvent-Acrylic-Plexiglass-Glue-4-oz-Applicator-2-needles-/122007661776?hash=item1c68392cd0:g NYAAOSwcldUZWru[/url]
