OrlyP
Flight distance : 36916 ft
Philippines
I use both apps but unless I am updating firmware or calibrating the sensors, I use Litchi more than DJI Go... Maybe 4 out of 5 times.
A couple of things I like about Litchi that are not available in DJI Go:
1. Pre-planning missions - I can create, save and sync my missions using a PC or tablet with the aircraft safely powered off and conserving battery. DJI Go requires you to actually fly to your waypoints to record them. DJI meant it to be a safe method in creating waypoints. I agree that they mean well, but I still decided to pre-plan my missions so I can get the results I want in one or two takes and without running down my batteries. Anyway, I tripple check everything after creating the mission and prior to the actual flight
2. Voice prompts - Among other spoken warnings or cautions, you can configure Litchi to regularly call out the aircraft's current speed. distance, altitude, and the battery's state of charge. Less squinting on your mobile device to look at telemetry
A few advantages DJI Go has over Litchi:
1. Flight Data Recorder - The FDR is particularly essential when claiming warranty during a fly-away condition, among others. In a more casual usage, it allows you to playback your previous flights
2. Updating firmware - Self-explanatory. It's probably a good idea for Litchi (or any 3rd-party app) NOT to touch the firmware
3. Sensor calibrations - IMU, compass, EXP, stick, etc.
Both apps are essential to me. My choice about which app to use depends on a particular outcome I need.
