Measure distances
14133 15 2016-9-7
userff49e54acc
Norway
Can you use the Phantom 4 to
measure distances (e.g. length on roof top)?
2016-9-7
MD_Icarus
Depends on the tolerance you are looking for?
2016-9-7
BaWCzfda4Vsa
Norway
We just want to measure the length and width of the roof. It don`t need to be 100% accurate (just approx).
2016-9-7
Dr AJ
Flight distance : 9311 ft
BaWCzfda4Vsa Posted at 2016-9-7 17:28
We just want to measure the length and width of the roof. It don`t need to be 100% accurate (just ap ...
Yes, you get a starting point of the flight, ask someone to note down the current distance, move along the roof, stop at the end, note down the distance. .... easy ....
2016-9-7
BaWCzfda4Vsa
Norway
OK. So there are no tools in the app that can measure distance, but you have to use the flight length? Correct?
2016-9-7
gmccurdy
Flight distance : 3 ft
I just measured my roof using Google Earth on the desktop.  Surprised to find out it was accurate within an inch with their Line tool.  The aerial photo Google has is fairly recent (Within a month as I moved stuff in the yard.) so the resolution is a lot better too.  Doing it by drone would be a lot more work and much slower.  I just checked my patio (Since it is on the ground) and it measured 178.45 inches in GE and I got close to the same ~1 inch).  I doubt if the drone will give you that sort of resolution.
2016-9-7
DJI-Ken
Flight distance : 1515312 ft
There is no feature in the GO app for measuring. There are mapping apps.
2016-9-7
DJI-Ken
gmccurdy@att.ne Posted at 2016-9-8 01:02
I just measured my roof using Google Earth on the desktop.  Surprised to find out it was accurate wi ...
I totally agree, Google Earth is pretty accurate and quick and don't have to risk your aircraft hitting a tree.
2016-9-7
BaWCzfda4Vsa
Norway
Thanks. We are going to measure roofs inside big building complex, so we cannot use Google. Anyone know an app we can use to measure images from a drone?
2016-9-7
cedthered
Flight distance : 1225827 ft
Sweden
You can do it with photogrammetry software.
Ago soft or pix4D is good.
You are going to need to scale it with pre measured control points or you can use known dimensions of objects or structures.But
I would not use the wide angle camera of a P4 or P3P...
2016-9-7
BaWCzfda4Vsa
Norway
Thanks cedthered
2016-9-7
labroides
Flight distance : 9991457 ft
Dr AJ Posted at 2016-9-8 02:36
Yes, you get a starting point of the flight, ask someone to note down the current distance, move a ...
Not so easy.
The distance shown is distance from home.
Unless home is in-line with the points you are measuring, you won't even be close.
2016-9-7
Dr AJ
labroides@yahoo Posted at 2016-9-7 22:20
Not so easy.
Unless home is in-line with the points you  ...
very easy ...
distance from home to roof point A noted, then distance from point A to point B noted, the difference gives the answer ...
very easy ...
and yes, i have done it ... home must be in line ...
simple mathematics mate ...
2016-9-7
Delta Nine
https://www.freemaptools.com/measure-distance.htm
2016-9-7
Delta Nine
2016-9-7
djiuser_5AhATTwzRfdn
BaWCzfda4Vsa Posted at 2016-9-7 10:02
I measure roofs with drone pics often.. i use roofr.com just upload a photo and trace the image.  You will need one measurement for scale.
1-23 16:33
