RichJ53
Flight distance : 1837356 ft
Based on my experience using the iPad mini 2 or 4 If you shot the video in 4K then no, you will not be able to download the files on your iPad using the Go App. When you select the editing tab from the main page then you can go to the top right corner icon page with arrow. Now you can select from three areas and the top selection is on-board SD. Now you can view the footage by selecting it and then watch it on the iPad (inside the Go App) edit preview window, but if it is 4K will not let you download it from the SD card.
I hope this helps and does not confuse you even more. I prefer to download the camera files onto my PC for editing. The Go App provides you with a quick edit feature if you want to use it
Please note, that while you navigate to the AC SD card, the AC needs to be turned on and connected to the remote / iPad.
Rich
