wmcvey
Flight distance : 904364 ft
Yes hand catching is the best way under controlled landings. But I think the OP was more concerned about an uncontrolled landing or lite crash. Personal I use a gimbal guard that goes under the camera connecting the two legs together. It gives a small bit of added protection to the camera/gimbal area right beneath it. By no means is the added protection 100%. But I also like the fact that it contacts the two legs together, so each leg has the other leg's added support. You do have to make sure you get one for the Standard, as the legs are different than the other Phantom 3's. Now you'll get others that will try to belittle these products because they say it blocks the camera when pointed straight down. That only happens if you bought one for the Adv/Pro model and not the Standard. Or that it's protection is minimal, and it's not 100% like I said. So beware of the naysayers. |
