Kneepuck
Flight distance : 275105 ft
endotherm Posted at 2016-10-4 12:59
You have to account for the elevation of everything along your flightpath. This is a shortcoming of Litchi, which allows you to set waypoints without flying it first, like the Go app requires. An oversight or miscalculation results in you flying into the ground. Remember, these aircraft have no ground sensor, they do not maintain a set height above the ground as terrain changes. It knows the altitude of the home point where it took off, but everything else is up to the pilot. Checking on Google Earth first would have showed an altitude of 200m at least was required to clear the terrain (that's 200m above sea level, not the takeoff point).
[view_image]Top of the "fence" is 200m ASL.
Even using Google Earth can get you in trouble. Things like telephone and electric wires are not very visible in them, and many do not use a uniform height. The best strategy is to fly the mission first, setting waypoints as you go along. After creating a mission in this way, you can then adjust mission parameters for each waypoint so you can get the shot you want without as much chance of disaster. In all cases, it is vital that you have a properly calibrated compass and imu for accurate results. And enough satellite coverage, of course.
