No Gimbal status GoApp 3.0.1
947 11 2016-10-22
AEROKAMERA
Flight distance : 2289429 ft
Poland
No Gimbal status, what's going on? (GoApp 3.0.1/firmware latest/iPad 4 Mini)
2016-10-22
Hi, please don't worry about it.
If the gimbal status is abnormal,it will show error message with red mark.
2016-10-23
AEROKAMERA
Poland
DJI Mindy Posted at 2016-10-23 12:01
If the gimbal status is abnormal,it will show error message with re ...
I'm worry about it because I noticed that gimbal drifts afert calibrate and yaw reset. My aircraft going to repair.
2016-10-24
DJI-Jamie
Flight distance : 112405 ft
AEROKAMERA Posted at 2016-10-25 00:33
I'm worry about it because I noticed that gimbal drifts afert calibrate and yaw reset. My aircraft ...
Have you already tried an IMU calibration and gimbal calibration in that order? Did you notice this after a firmware update or a hard landing?
2016-10-24
AEROKAMERA
Poland
DJI-Jamie Posted at 2016-10-24 22:58
Have you already tried an IMU calibration and gimbal calibration in that order? Did you notice thi ...
No crash, no fly, on ground after IMU and gimbal clibration. I've tried everything already, so sent aircraft to repair 4th time.
2016-10-25
DJI-Jamie
AEROKAMERA Posted at 2016-10-26 03:41
No crash, no fly, on ground after IMU and gimbal clibration. I've tried everything already, so sen ...
Is it doing this right after getting it back from repair?
2016-10-25
AEROKAMERA
Poland
DJI-Jamie Posted at 2016-10-26 00:14
No, I noticed it few days ago, because a didn't fly after last repair
2016-10-26
DJI-Jamie
AEROKAMERA Posted at 2016-10-27 00:45
Did the last repair also have to do with gimbal drift? Could you happen to provide your last RMA number? I just want to ensure that your current case is followed up accordingly.
2016-10-26
AEROKAMERA
Poland
DJI-Jamie Posted at 2016-10-27 00:30
Did the last repair also have to do with gimbal drift? Could you happen to provide your last RMA nu ...
No, another camera issues was to do (RMA CAS-186420-Z2G0W0).
Now my I1Pro is under repair (RMA CAS-291375-R5D2M2)
2016-10-28
DJI-Jamie
AEROKAMERA Posted at 2016-10-28 19:09
Now my I1Pro is under repair (RMA CAS ...
Thank you for supplying this. Just to make sure I'm on the same page, the camera that's having the drifting is the same one that was sent with the aircraft in CAS-291375?
2016-10-28
AEROKAMERA
Poland
DJI-Jamie Posted at 2016-10-29 00:23
Thank you for supplying this. Just to make sure I'm on the same page, the camera that's having the ...
Yes. Never I didn't change it by myself.
Got message from DJI Support that my Inspire is returning home. Repaired I hope
2016-10-29
DJI-Jamie
AEROKAMERA Posted at 2016-10-30 03:54
Got message from DJI Support that my Inspire is returning ...
It looks like you should be all set! Please let us know if the issue persists when you receive your unit back.
2016-10-31
