Donnie
Flight distance : 3636782 ft
If the battery is under warranty just send it in. If not what I would do is go to you tube and watch videos on how to revive them. It is fairly simple to do . Just remove the Main cover very gently by prying off , then disconnect the main wiring harness form the battery, leave un- coupled for about 5 min then reconnect and try to charge. Only do this if you are Mechanically inclined , also pry it off very gently and treat that battery with respect .
Charge this battery with full time supervision to make sure it is OK, what I do is work on other projects but keep an eye on that battery . If it shows any type of bulging Now or during charging process, the battery is toast.
The battery life span is about 200 charges give or take depending on how well taken care of , keep this in mind as it could be just times up on the battery .
***I highly doubt the batteris were bricked during the update, there is an update to the batteries that was in all AC updates after 1.5 ( I think , somewhere around here ) but I cant say for sure , I was not there to see what happened .
good luck
donnie
