I am trying to get my osmo moblie set up and it was working fine. Then when I shut it off and came back to it I was using the joy stich and in one direction I get a message on the camera screen that says "Unable to rotate. Adjust gimbal attitude". I can't figure what I have done wrong or how to fix it. Any help would be great.
Yes I did try that. I went thru the calibration procedure fine bt it still has the same issue. It is only when I try and move the gimbal to point up. Pointing down and side to side is fine.
olcmike Posted at 2016-11-3 22:39
Is there a way to to do factory reset? I have tried everything and I don't know what else to do? Cou ...
I'm sorry to say that you need to return this unit. Contact the seller to see if you can get a direct exchange, if not contact DJI via www.dji.com/support and follow instructions to send it in. Thank you.
