I've just noticed that my rate of climb when initiating fail safe is slow as molasses! I have the altitude set at 200' and when I tested it in the past it would climb from ground level to this height in a jiffy. Now it is climbing slower than the default maximumndecent rate! It is also noticeably slower when using Ground Station. Anyone know what the default climb rate is when using these two features and/or how do you set it? I did not see any settings for this in the software.
Well I saw the post on problems with the new firmware and the suggestion to roll back to V3.08. I did that just now and it solved the problem. Ascent rate back to what it was before the upgrade to V3.10. I guess one of the reasons to postpone V3.10.
