fans59eebc9d
Greece
I had the same problem and I lost MAKING A degradation of the ROM with some older MAY 2016.
!!!! Tutorial how to fix WITCH PROBLEM LAST S7 FIRMWARE !!! Everything you do at your own risk!
Only way to fix is the firmware downgrade. . It is very easy process
You should:
1. Download latest Odin http://odindownload.com/
2. Find the correct firmware version for your phone. Go to http://updato.com/firmware-archive-select-model
Search Galaxy S7 and the filter model area. Watch out! Wrong version can brick your device !!!
On my way samsung is SM-G930F region Poland (XEO). Firmware with error is G930FXXU1BPH6 and downloaded G930FXXS1APG3 previous version. Check the release date, do not sort. Unzip the file. You will see five files.
3. Next step is to fully wipe your phone, if you need to make a backup !! Turn the security option as Find your phone, etc. Deletes the Samsung account. When setting go to the factory setting and do it. After restarting my phone disable
and simultaneously press UP volume, home and power. Recover wipe data and cache memory reset too. Turn off the phone.
4. open the Odin application admin. Press BL and select the firmware file to the first BL-mail. Next AP and Ap file - May couple of second to load the file, the next CP and the CP file. !!!IMPORTANT!!!! In CSC should choose HOME_CSC ... NOT only CSC choose !!!
5. Phone is off, press the volume key downwards, home and power, you will see the warning about custom rom. Press volume up to continue. You are in Download mode.
6. Connect your phone to the computer. In Odin should see ADD calendar. If not check usb driver, reinstall or Odin support.
7. In the selection tab controls only Auto Reboot and time F.reset.
8. If every thing is ok Press Start and wait for reboot.After degradation do not update my phone select automatically updated.
I tested with full battery time and any problem! After degrade not miss KNOX warranty is still 0x0 !!!!! !!!!! |
