How to fly low over water?
6978 21 2016-11-18
yoengel
Flight distance : 2370988 ft
I want to get some low shots close to the water, I'm curious to know what the best practices are, like how low can you go and do you turn off VPS.  I imagine it depends on the wind speed and how strong the waves are in the water, ie. calm lake vs. ocean waves.
Would like to hear about your experiences for both.  Thanks.
2016-11-18
ctopysf
Definitely turn off VPS over water. Buddy of mine had his mavic nearly drift into a bridge over a river because it was following the current below. Beyond that, it won't actually help you in any way over water...you're asking for trouble if you leave it on.
2016-11-18
fans4315cba9
What's vps?
2016-11-18
Wandering Cloud
Flight distance : 839633 ft
Vision Position System i.e. front and bottom sensor.
2016-11-18
yoengel
My first test flight over water.  It was about 20 feet above the San Francisco Bay.  VPS turned off.
2016-11-19
devGOD
Flight distance : 200577 ft
yoengel Posted at 2016-11-19 12:27
My first test flight over water.  It was about 20 feet above the San Francisco Bay.  VPS turned off. ...
where is the setting for turning VPS off?
2016-11-19
fansbb5b373a
devGOD Posted at 2016-11-20 08:34
reading the manual..
you can flight in
P mode: all sensor are on (vps): front and botton
S mode: all sensor are of (no vps) ..
so i think to use the mavic whitout VPS you need to flight in S mode..
so that is what i understand reading the manual
2016-11-20
Wandering Cloud
fansbb5b373a Posted at 2016-11-20 08:44
you can flight in
You can turn VPS off in VPS menu.
2016-11-20
Wandering Cloud
yoengel Posted at 2016-11-19 17:27
Have you try with VPS on? I really don't know why it should make any difference either way.
2016-11-20
AusAir
Flight distance : 425049 ft
Less than 3ft from the water yesterday with VPS on no issues.
2016-11-20
yoengel
AusAir Posted at 2016-11-20 17:59
How many times have you done this and how fast was the water moving?
2016-11-20
yoengel
Wandering Cloud Posted at 2016-11-20 16:55
I haven't tried it with VPS on.  The manual says VPS may not work and have read and saw videos saying to turn it off when flying over water because the drone gets confused with trying to track moving water.
2016-11-20
Wandering Cloud
AusAir Posted at 2016-11-20 09:59
That's good to know!
Cheers!
2016-11-20
Wandering Cloud
yoengel Posted at 2016-11-20 18:28
I haven't tried it with VPS on.  The manual says VPS may not work and have read and saw videos say ...
That makes sense too. Although if you are not trying to land it shouldn't be a problem, should it? I think I will find out soon as I am off cursing for a  long time next week.
2016-11-20
trance728-
Flight distance : 298048 ft
Wandering Cloud Posted at 2016-11-20 14:33
That makes sense too. Although if you are not trying to land it shouldn't be a problem, should it? ...
With moving water the vps might try to follow it so the drone won't stay in a stationary spot and could be pushed into something you don't want it to.
2016-11-20
[Rockhound]
I tryed both. P-Mode with and S-Mode without VPS. Both worked very good. At some point i was less than one meter away from the water.
Here is my footage from yesterday. It was very windy, but the Mavic did a good job!
https://youtu.be/l4SVkugy4IQ
2016-11-20
[Rockhound]
[Rockhound] Posted at 2016-11-20 21:36
I tryed both. P-Mode with and S-Mode without VPS. Both worked very good. At some point i was less th ...
2016-11-20
yoengel
Wandering Cloud Posted at 2016-11-21 03:33
Digital Rev flew it over the water and it did try to land over water.  I assume they had the default settings, which includes VPS on.
2016-11-20
yoengel
[Rockhound] Posted at 2016-11-21 04:36
Good to know, the water was relatively still it seems.
2016-11-20
stealle
Flight distance : 21827 ft
Nice video... Less than 1 meter?! I'm sure its an optical illusion, but it looks like less than 6 inches around 2:41.  And, that must be sport mode with the props showing so much in the video, right?
2016-11-20
AusAir
yoengel Posted at 2016-11-21 02:27
I've done it more times than I can count over slow moving reasonably calm water.
If there are ripples on the water, you may experience some drift with VPS on during a hover or slow forward momentum although this doesn't always happen.
2016-11-20
[Rockhound]
stealle Posted at 2016-11-21 01:58
Nice video... Less than 1 meter?! I'm sure its an optical illusion, but it looks like less than 6  ...
Yes, that was sportmode.
2016-11-20
