endotherm
Flight distance : 503241 ft
I don't now why you had/have connection problems. Looks like you might need to do an IMU calibration and check your antenna orientation.
Your flight log looks OK, you were in ATTI mode for the whole flight, except for the autotakeoff. No other warning messages. You would likely have had the switch in the wrong position, there were ample GPS satellites if you were using that mode. The flight path looks like a normal flight flown in ATTI mode with an poorly defined track. In ATTI the aircraft does not necessarily fly in the direction it is facing, and could well have been blown back towards you even though you were facing the other way. I notice you were facing south to east a lot of the time on the way back home to the west. It would appear to be travelling sideways or backwards in this orientation. |
