DRONE-flies-YOU
Flight distance : 1450594 ft
The P4P+ is excellent. I am in no way disappointed. That said, I've found a couple issues that look easy to address:
1. Map doesn't follow the drone - ever. fullscreen, minimap. Re-select the target button, select the drone. Nope.
2. Mini map doesn't zoom in/out or remember a zoom level after coming out of fullscreen map - makes it even MORE useless with the combination of HERE
3. Shows "RAW" after P4P auto-reverted to JPG after a power cycle. Re-selecting RAW format then shows correct number of shots available (1800 RAW vs. 7000 JPG in my case) - it's reverting to JPG after a power cycle but showing RAW!
4. MPH (Imperial) is selected, but it's showing speeds consistent with KPH. I somehow hit 17MPH climbing in P-MODE (vertical speed) and over 67MPH horizontal speed in SPORT! Mavic did this.
5. P4P+ built-in screen HDMI toggle in Notification panel reverts to ON after a power cycle, even if previously OFF
6. Tripod Mode is missing - SOLVED
7. Draw mode is missing - SOLVED
8. The internal clock is wrong in the P4P. Files on the micro-SD card say "yesterday" and the time is -16 hours, so my P4P thinks it's in China.
9. Lightroom shows the altitude as -21.4 feet or something. HERE is a photo ran thru LR - taken 1 minute before sunset - NOT BAD! altitude was 200+ feet AGL
*** I plugged-in to DJI Assistant 2. It said I have November 3rd's firmware x150. Newest is November 25th's firmware x201. It adds the AR route tapfly for reverse tapfly, draw, tripod, increases maneuvering speed during spotlight, and support for mechanical shutter (I thought I noticed some electronic shutter 'stuff'). The app (P4P+ built-in) said "Latest firmware".
-END-
