Mavic Check List
3286 11 2016-12-4
fansa5e1fb66
Hi to All
It seems to be very important to have a tried and trow Check list with the Mavic. This hopefully will help some of us stay out of trouble. Have been working on this list for some time know. Please give feed back on any changes or additions.  This is Bast on a Tablet not a phone. should work with a phone.Updated on 12-5-2016
                                             Mavic Check List
Prior to Delivery
Read the quick start guide cover to cover
Read the manual cover to cover
Watch all DJI Tutorials
Subscribe to DJI Youtube channel
Print FAA UAV Registration and put it in my wallet
NOTE: You should be totally confused at this point. LOL
Post Delivery Inspection
Remove all stickers
Remove Gimbal Clamp
Remove Gimbal Cover
Check batteries for deformation
Check mavic body for deformation
Check gimbal clamp is properly secured to body
Check Lens for Dust or Mold
Preparing for First Flight ( performed outside for first flight)
Charge Batteries Upgrade Firmware on each battery (Only if prompted)
Upgrade DJI Go App (Only if prompted)
Update Firmware (Only if prompted)
Power up controller then  tablet, Power up Mavic, Open DJI-GO App, Turn off WiFi, Put Tablet in Airplane Mode
(If flying over water turn off VPS, S mode all sensors are OFF)
Close all other Apps (See How to close all open apps)
Confirm batteries are looking good in DJI Go App
Calibrate Compass (outside, no metal on my person or nearby)
Confirm IMU is looking good in DJI Go App
Confirm stick inputs are tracking correctly (note, I am not planning to calibrate the controller out of the box unless I see a problem here)
Calibrate Gimbal
Take still photos and look for blurry sides or gimbal alignment problems
Adjust gimbal roll if necessary
Take video and look for blurry sides or gimbal alignment problems
Adjust Mavic Pro Settings per checklist below
Register Drone with DJI
Purchase DJI Care Refresh from DJI
Attach FAA UAV sticker
First Flight (large open clear area)
Turn on controller
Turn on droneTurn off WiFi, Put tablet in Airplane Mode
Start DJI Go App
Confirm GPS lock
Confirm Home Point Set correctly
Set RTH Altitude to appropriate height  (To” appropriate RTH altitude” not a # ) Forward Obstacle on
Focus at infinity
Start video recording
Take off, hover at 30 ft for 10 seconds to acquire precision landing image (page 15in Manual)
Confirm VPS reading
Verify gimbal wheel
Verify Exposure wheel
Verify C1 button
Verify C2 button
Verify 5D button
Confirm Pitch response
Confirm Roll response
Confirm Throttle response
Confirm Yaw response
Fly Boxes
Fly Circles
Land before battery failsafe RTH
Confirm total flight time.
                             HOW TO CLOSE ALL OPEN APPS
Tape the home icon then tape the two squares beside it.
All open Apps will be shown.
Touch and slide each App to the left....it'll close.
Then tap on the home icon and open DJI GO App
Mavic Pro Settings Checklist
MC Settings
  Turn off beginner Mode (wait for second flight to do this)
  Enable Multiple Flight Mode (wait for second flight to do this)
  Set RTH Alltitude (To "appropriate RTH altitude" not a #) Forward Obstacle on
  Set Maximum Flight Altitude (Check 400ft.)
  Disable Maximum Distance (wait for second flight to do this)
Advanced Settings
  EXP
  Rudder lift/right 0.3 (Adjust to liking)
Sensors
  Confirm IMU Status as Good
  Smart Go Home enabled
Visual Navigation System
  Turn on Forward Obstacle Sensing
  Allow Horizontal Obstacle Avoidance
  Disable Backward Flying
RC Control Settings
  Check button customization
Aircraft Battery
  Auto Discharge 3 days
Gimbal
  Gimbal Tilt EXP- 50 (Adjust to liking)
  Gimble Tilt Smoothtrack-17 (Adjust to liking)
  Enable Synchronized Gimble Pan Fallow
General Settings
  Imperial
  Disable Youtube live Steaming
  Cache Map in background Enable
  Video Cache- Disable
How to close all open apps, (Close all other Apps (See How to close all Apps)
If your not totally confused know, You are a Genius. LOL
2016-12-4
FPVJunkie
Flight distance : 66421 ft
One thing that I noticed that is missing that is covered in the manual is to turn off your wifi on your device. Also on that same note, put your device in Do Not Disturb or Airplane Mode prior to flight.
2016-12-4
CamStevens
Just curious why you copy/pasted this from my original post, rather than continuing to offer your own edits?
http://forum.dji.com/forum.php?m ... &fromuid=421841
2016-12-4
cluc
Flight distance : 85682 ft
CamStevens Posted at 2016-12-5 09:41
Just curious why you copy/pasted this from my original post, rather than continuing to offer your ow ...
exactly my thoughts.
2016-12-4
colonel00
Because it's tried and trow (sic)
2016-12-4
rick39
Flight distance : 164354 ft
colonel00 Posted at 2016-12-5 07:52
What does trow mean?
2016-12-5
fansa5e1fb66
CamStevens Posted at 2016-12-4 18:41
http://forum.dji.com/forum.php?mod=viewthread&tid=71599&fromuid=421841
I had started a list, then came across yours, I used your post for most of the list then did some changes to make it work for my setup.
You are one of the people in the forum that is making a difference. Isint that what the forum is allabout. Shearing info.
Thank you for your work.
2016-12-5
colonel00
fansa5e1fb66 Posted at 2016-12-5 04:17
Shearing (sic) info....ironically true
2016-12-6
edwarde21
Flight distance : 65535 ft
this is useful
2016-12-6
fansd39752d0
FPVJunkie Posted at 2016-12-4 13:24
I have heard both. As a new pilot can you explain which is correct and why?
2016-12-7
FPVJunkie
It is stated at the top of page 17 in this manual: Mavic Pro Disclaimer and Safety Guidelines v1.0 (http://www.dji.com/mavic/info#downloads). Obviously this is only when you are using the RC as the controller and not your phone though. As far as the reason why, I believe it's because the RC and aircraft communicate on the 2.4gHz spectrum and a majority of Wi-Fi uses the 2.4gHz spectrum, they may not operate in the same frequency range, but there is a chance for bleed over. In regards to Do Not Disturb, I wouldn't want to be in the middle of taking a shot or flying close proximity to something and have an incoming phone call show up on my screen. Of course you should be LOS, but that doesn't mean you can judge the distance from an object.
2016-12-7
rick39
fansa5e1fb66 Posted at 2016-12-5 12:17
All for sharing info and love the list, but I guess CamStevens would have appreciated being credited for his list and original idea to post such a list. Not having a go but for the sake of peace, love and harmony we should at least try and get on with each other, after all we share the same common interest. I try to love everyone, even the ones I don't like very much........but CamStevens is my favourite Mavic Check list topic starter.
  xxxx
2016-12-7
