Oh, I'm not sure why it isn't showing that part of the info?
The app will tell you if a newer firmware version is available.
Then once you do the update, the message will not be seen.
Are you getting any update messages?
Normally the About page should tell you all three versions, as the numbers are all different.
If yours aren't showing up, I'm stumped. Not sure what's going on.
You could check the release note, all-in-one firmware version is V1.7.9. Here is the link: http://dl.djicdn.com/downloads/p ... rd+Release+Note.pdf
May I know have you tried to delete the APP and re-install the APP, then check again if it's still V1.7.90+?
RedHotPoker Posted at 2016-12-5 01:08
So would this indicate that my drone/rc is defective?
I don't have a firmware version for my R/C on that page of the app for my P3S, I think this is normal for the P3S as the firmware update is downloaded from the dgigo app , you have the latest firmware showing for the P3S so your R/C will be upto date
No, perhaps the Standard has a slightly different system, so it may not show in there for you.
If you aren't getting a prompt to update, or that a new version is available, you are probably good.
Admittedly, I am not very well versed in Phantom Standard protocol. ;-)
freelanderuk Posted at 2016-12-5 10:20
Thanks buddy, it's nice to have input from someone with the same drone.
RedHotPoker Posted at 2016-12-5 11:29
And, thank you for your time to help me on this issue
