Flight distance : 256686 ft
Hello All,
I'm flying with a S900, A2, Lightbridge, BMPCC and 2 Futaba radio's (Drone + Camera).
For the IOC (Intelligent Orientation Control) function I've asigned a 3 position switch on the radio.
In the assitant software I've assigned as described in the manual the switch position as OFF(1) - CL(2)- POI(3).
When flying above a POI, I can't record the POI.
Here is what I do.
Hovering above the POI. Then I flip 3 to 5 times the switch between CL and POI.
If I end this sequence of flipping the switch on the POI setting, nothing happens, I do not see the blue light flashing 20 times. So I can not record the POI.
If I end this sequence of flipping the switch on the OFF setting, nothing happens, I do not see the blue light flashing 20 times. So I can not record the POI.
If I flip the switch to CL, on my screen connected to Lightbridge I will see CL appear in the left up conrner.
If I flip the switch to POI and the drone being more than 5 meter away of the POI, on my screen connected to Lightbridge I will see OFF appear in the left up conrner.
What am I doing wrone?
Any advice would be very much appreciated!
Thank you,
Eugene
