Nigel_
Flight distance : 388642 ft
You could press pause, walk round the other side of the building and then continue...
I think it would be better to do the two sides of the building separately at different heights, distances, and times of day so that there is an obvious reason for the cut. A point of interest in a perfect circle is never that interesting and generally means that the lighting is wrong on half the circle, you at least want to vary the diameter as it circles and do an ellipse or spiral. Even better to fly it manually, and having a cut or two between segments will not harm the result if done right.
Whatever you do, practice it on open ground with plenty of space first, including turning off the remote to simulate loss of signal, then you will know what can go wrong and how to deal with it.
And remember that you are not allowed to fly over "built up areas"! |
