fansc53c1d1e
Pakistan
DJI Natalia Posted at 2016-12-10 14:02
The camera sensor is 1/2.3 inch and image size is 6.3116*4.7492mm.
You could check it's spec on DJI website as well: http://www.dji.com/phantom-4/info#specs
Thanks.
You mentioned the image size as 6.3116*4.7492, but I guess it should be "sensor size" and not the image size....YES??
Moreover, the lens focal length is mentioned (on the DJI website) as 20 mm (35 mm format equivalent). Please clarify we should take it as 20 mm OR 35 mm.
Regards, |
