RedHotPoker
Flight distance : 165105 ft
DJI-Jamie Posted at 2016-12-10 23:47
There is a difference between a little warm and extreme overheating. If you feel that the gimbal is extremely overheating, then you may want to send the unit in to DJI for further evaluation.
Something I appreciate that the Go app tells us is the ongoing battery temperature. Which can be a great guide to follow and I suggest others to use that as a way of understanding how the battery warms and gets hotter through normal use. What some may think is too hot, may be completely normal for our Phantoms intelligent flight battery's.
Check it frequently during flights, then make comparison to those figures while using the flight SIM.
If you see the temperature rising too fast, or getting beyond safe operating temp, then shut it down, or place it on top of a fan while it's operating... Respect the numbers, but be aware of normal use heat buildup as well. ;-)
The gimbal heat is similar, it is supposed to get warm through use. If yours is overheating, yes, send it in for proper evaluation. ;-)
RedHotPoker
