Donnie Stugots
Flight distance : 3636782 ft
If you were having trouble before the update then its not that . If you have done all my suggestions and still have trouble , may need to send it in , sounds like the gimbal motor is broken , the only other thing I can think of is to Inspect the 2 black flat wiring harness's for any kinks or loose connections , also make sure the camera and gimbal are meshed nicely together and you are not having a bad connection there .
good luck
donnie |
