Barometer Error after up-/downgrade
1808 4 2016-12-16
fans9da18164
Hi Pilots,
First of all ... sorry for my worse english! I am just a german! ;-)
A couple of day ago i bought a new P3S. First flight with no problems. After the first flight the app said that there's a new firmware. So i do the update. On my second flight i mentioned that the video signal is lost just after 50 meters, but i can returned. I read a lot here and once someone from dji meantioned to downgrade the firmware to see if the problems will be fixed. So i downgrade the P3S Firmware to 1.6.07 without any errors, but after restarting the copter a mcu Error lights up in dark red and it says that the barometer has an error. I still tried to calibrate the IMU, and/or up- and downgrade the firmware again. The error is still there.
Anybody a suggestion how to fix it? I don't think that it is a hardware failure, cause it just happened while downgrading.
2016-12-16
Betamace
Flight distance : 2133 ft
You didn't have to upgrade it. Open a ticket, you might even get a free replacement.
2016-12-16
zerberus1971
Betamace Posted at 2016-12-16 13:17
sure, i just thought that there will be a easy and simple solution, cause i don't want to wait weeks till i get it back! ;-)
2016-12-16
Could you please find the update log file and post it here? I'll help to check it.
You could find the update log file by following these steps:
1. Enable Viewing hidden files in your OS. Below are the websites where you can check how to show the hidden files in your PC.
For The Windows System:
http://windows.microsoft.com/en- ... den-files=windows-7
For The Mac System:
http://ianlunn.co.uk/articles/qu ... mac-os-x-mavericks/
2.Enter the root directory of the SD card, then find the hidden folder MISC and enter it. There is LOG folder in it.
3.The LOG txt file is under the LOG folder.
2016-12-18
fansd4765c21
I am having the same problem my log file is:
[00128017]========== 2016.12.26 09:52:09. boot(15) ============
[00128148]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x85b93c32].
[00128182]Packet upgrade start...
[00128224]Packet checking...
[00128306]Packet vlink 01.07.0090 <-> 01.06.0080.
[00128341]Done.
[00128381]Version checking[1]...
[00128416][01 00][00] v1.14.4920 -> v1.14.4920 need upgrade
[00128455][01 01][00] v1.14.4920 -> v1.14.4920 need upgrade
[00128537][03 05][00] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00128607][03 06][00] v2.4.20.22 -> v2.4.15.5 need upgrade.
[00128665][04 00][00] v1.51.0.0 -> v1.51.0.0 need upgrade.
[00128734][09 00][00] v0.1.0.9 -> v0.1.1.0 need upgrade.
[00128847][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00131469][11 01][00] v1.7.0.0 -> v2.0.0.33, firmware v1.7.0.0 not support.
[00131502][11 01][00] v1.7.0.0 -> v2.0.0.33
[00131612][12 00][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00131738][12 01][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00131812][12 02][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00131937][12 03][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00131972]Done.
[00134003]Waiting for user confirm...
[00144038]Timeout, start upgrade automatically.
[00144114]Firmware upgrading[1]...
[00161343][01 00] Firmware upgrade start...
[00013840][01 00] Firmware upgrade finished successfully.
[00013896]Done.
[00013947]Packet [C:\P3C_FW_V99.99.9999.bin] resumed, card sn [0x85b93c32].
[00014006]Packet vlink 01.07.0090 <-> 01.06.0080.
[00014048]Version checking[2]...
[00014081][01 00][05] v1.14.4920 -> v1.14.4920 need upgrade
[00014116][01 01][00] v1.14.4920 -> v1.14.4920 need upgrade
[00014231][03 05][00] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00014312][03 06][00] v2.4.20.22 -> v2.4.15.5 need upgrade.
[00014355][04 00][00] v1.51.0.0 -> v1.51.0.0 need upgrade.
[00014416][09 00][00] v0.1.0.9 -> v0.1.1.0 need upgrade.
[00014550][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00014669][11 01][00] v1.7.0.0 -> v2.0.0.33, firmware v1.7.0.0 not support.
[00014856][11 01][00] v1.7.0.0 -> v2.0.0.33
[00014976][12 00][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00015069][12 01][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00015158][12 02][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00015261][12 03][00] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00015296]Done.
[00015327]Firmware upgrading[2]...
[00015489][01 01] Firmware upgrade start...
[00045785][01 01] Firmware upgrade finished successfully.
[00045832][12 00] Firmware upgrade start...
[00085260][12 00] Firmware upgrade finished successfully.
[00085299][12 01] Firmware upgrade start...
[00124709][12 01] Firmware upgrade finished successfully.
[00124749][12 02] Firmware upgrade start...
[00164049][12 02] Firmware upgrade finished successfully.
[00164091][12 03] Firmware upgrade start...
[00203650][12 03] Firmware upgrade finished successfully.
[00203691][11 00] Firmware upgrade start...
[00252380][11 00] Firmware upgrade finished successfully.
[00252445][03 05] Firmware upgrade start...
[00326787][03 05] Firmware upgrade finished successfully.
[00327044][03 06] Firmware upgrade start...
[00690416][03 06] Firmware upgrade finished successfully.
[00690476][09 00] Firmware upgrade start...
[00716840][09 00] Firmware upgrade finish without reboot.
[00746882][09 00] Firmware upgrade finished successfully.
[00746957][04 00] Firmware upgrade start...
[00805883][04 00] Firmware upgrade finished successfully.
[00805919]Done.
[00805954]Version checking[3]...
[00805992][01 00][05] v1.14.4920 -> v1.14.4920 need upgrade
[00806027][01 01][05] v1.14.4920 -> v1.14.4920 need upgrade
[00806120][03 05][05] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00806197][03 06][05] v2.4.15.5 -> v2.4.15.5 need upgrade.
[00806234][04 00][05] v1.51.0.0 -> v1.51.0.0 need upgrade.
[00806283][09 00][05] v0.1.1.0 -> v0.1.1.0 need upgrade.
[00806400][11 00][05] v1.8.0.0 -> v1.8.0.0 need upgrade.
[00806541][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00806572][11 01][00] v1.8.0.0 -> v2.0.0.33
[00806782][12 00][05] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00806873][12 01][05] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00806959][12 02][05] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00807042][12 03][05] v5.9.0.0 -> v5.9.0.0 need upgrade.
[00807079]Packet upgrade finish successfully.
2016-12-26
