indoor opti issue
875 5 2016-12-22
hijakd
hey guys just tried flying indoors today and found my mavic going from opti mode to a
weak gps mode,i really don't want gps indoors,any ideas?
2016-12-22
nils.heidorn
Flight distance : 183537 ft
Hi !
No other idea then DJI giving us ATTI / OPTI as a choice for the sports switch. weak GPS is dangerous.
Nils
2016-12-22
Jimney
Flight distance : 103268 ft
There is no manual override to set Atti that you could do on older models. For safety sake I would make sure that you have set your RTH height to below your ceiling height just in case you hit RTH in a moment of panic whilst it did have a GPS lock and your pride and joy would just rise up and try and shave the paint off your ceiling.
2016-12-22
nils.heidorn
Jimney Posted at 2016-12-22 16:13
You can also set signal loss to just hover..
Nils
2016-12-22
lildevilx
Flight distance : 264101 ft
nils.heidorn Posted at 2016-12-22 11:30
Nils
better yet, have it throttle down if its indoors anyways...
i'm sure you'll be able to run to it and catch it by hand if anything
2016-12-22
hijakd
yes the other issue is that it drifts badly indoors in gps mode,dji should fix this issue so you can choose which mode you actualy need
2016-12-22
