Not A Speck Of
Flight distance : 666493 ft
Ha, you trickster, not even telling them about the sekrit hand shake!
Kidding. If you're getting a constant beeping, it could be that you a) tried to update the firmware and b) stopped the process before it was finished.
Because after a bunch of firmware updates, the only time it BEEPED repeatedly like that is when I did the same thing. Normal, successful upgrades chug, but don't beep.
The solution is to start over. Unfortunately, during the re-do, you will have to endure the loud beeping (because it still knows that the internal firmware went south on you last time). If you can hide the thing in the basement for 30 minutes while it completes, that's best.
Cheers,
Ciao,
Aloha.
