DJI-Jamie
Flight distance : 112405 ft
CheapEngineer Posted at 2017-1-4 15:18
Well, thanks for the reply. My boss was told by the salesperson @ DJI that this system would allow for a clean HDMI output *with this adapter*, which we purchased ($99). So now I have an adapter I can't use (it doesn't even fit this model) but I will have to swipe the OSD info from the screen to go live. I will talk to DJI sales about a refund for the adapter, and I guess await the next DJI purchase I make in a couple of years for that feature and make do with what we have for now.
Unfortunatly, there wasn't a link for the adaptor (if that's what you were trying to do with the asterisks), but I'm assuming you mean this one:
http://store.dji.com/product/phantom-3-hdmi-output-module
If so, that would have only applied if you got the P4P with the standard (USB out) remote that requres for use to use a mobile device. You would change out the USB module in the back and then install the new HDMI output module. The remote for that RC is awaiting a firmware update for that HDMI module to be more reliable, but that could be a way to get what you want.
If you want to keep the P4P+ RC, then you would be limited to what was mentioned previously, and you should be well within the refund time frame if you just got the HDMI output module. You can also, when the update is made available, change out the P4P+ RC for the P4P RC and install the HDMI module then. The latter would require for you to switch out to your own mobile device for the Go app. |
