Warning Strong Interference, Be careful flying long distance
1384 11 2016-12-28
Mike-N-Tampa
Flight distance : 362894 ft
Any idea what causes this, I have seen it twice
2016-12-28
MerlinL14
Flight distance : 2858 ft
Flying too far away!
2016-12-28
Mike-N-Tampa
Was less than 150 feet in front of me 45 alt
2016-12-28
Ciro Italy
have you 1,6.8 firmware? you should upgrade to 1.7.9
2016-12-28
Mike-N-Tampa
I think so, how can I verify
2016-12-28
Mike-N-Tampa
Ciro Italy Posted at 2016-12-28 10:27
3.1.1 Ipad
1.7.90 Aircraft
2016-12-28
Microcyb
Flight distance : 1095955 ft
Well Cap, A few things to consider.  When flying, a good LOS (line of sight) is important, and also position of the antenna to the bird.  So buildings, home, and how far you are will affect your signal.
2016-12-28
Mike-N-Tampa
Microcyb Posted at 2016-12-28 10:33
Well Cap, A few things to consider.  When flying, a good LOS (line of sight) is important, and also position of the antenna to the bird.  So buildings, home, and how far you are will affect your signal.https://www.youtube.com/watch?v=lJ5WJKcu3HI
Got it when it was on ground too
2016-12-28
Microcyb
Mike-N-Tampa Posted at 2016-12-28 10:47
OK, well let us start off with a few basic questions.
Which model bird do you have?
Do you have a lot of homes in the area you are flying?
Are there any above ground power lines?
2016-12-28
proimages
Flight distance : 1004731 ft
seems a large batch of P3S have issues with firmware past 1.6.8 I had one..1.5.7+ worked great 1.6.8 never once worked great..1.7.9 is working on replaced craft..2 bits
I have a second P3S and will test distance soon. (both are setup and using same modified remote)
cheers D
2016-12-28
fredq2
Flight distance : 133287 ft
I have had that flying in parking lot of a condo complex with lots of wifi antennas on the exterior of the buildings
2016-12-28
Orlando_Jeff
Flight distance : 49147 ft
I get that alot since I upgrade to 1.79 firmware but it's an easy fix....buy the litchi app.
2016-12-28
