Cetacean
Flight distance : 2528264 ft
Aloha Chipper,
After taking into consideration and doing what Jamie and Pina said, try to see if this is the problem. The P4 battery default setting is to start draining the battery after three days. If the battery is stored waiting sale for two weeks or more, the battery is going to drain and possibly drain so much that it shows no lights for as much as a half hour after it is plugged in.
If you try to test this, check it every five minutes for heat and the lights of course. There should be almost no heat from charging since it is well metered, certainly no more than what it would be if you heated it in your hands for that amount of time. After a flight, you will know what a hot battery is like.
Hope this helps!
Aloha and Drone On! |
