Jason Lane
Flight distance : 260144 ft
Philippines
gibbd Posted at 2017-1-11 01:45
Technically, to work your way through the app settings and features, you dont need the phone or controller on, but you cant actually change any of the settings and many of the features wont show up.
Personally, as a beginner as well, I found that you can at least look where various settings can be changed to speed up the process when the drone/controller are attached. So to answer you question, reallisically you need the drone/controller on and connected, but you can access some menus (JUST TO VIEW) without the drone/controller on
Sort of, but not quite... I can view most of the aircraft's settings, but there are several settings that don't display until you enable something else, and since you can't enable anything without the aircraft connected, I don't think there's any way to get to those hidden settings.
Also, I can't even view any of the camera settings in the app without the aircraft connected. |
