fansee955acb
I faced same problem, and fortunately I attempted to solve it and success. Because the first several times it always stuck at 70%, and I tried to add some pieces movie to be longer, and then the movie creation was stuck at 40%, then I checked the position stuck seems a same place, that is a 1 second slice. then I delete it and re-create the movie, then it is smooth and successful. So I guess it is because the cut slice is too short (only 1 second) but I am not sure. However, I think it will be good if you dont use any 1 second cut piece in the movie. so you can try. good luck! |
